I have made some vcd's and I was wondering if I could up the quality by fiddling with the settings. I tried converting to svcd but I could not fit them on 2 cds. If anyone has some ideas It would be very helpful, thanks.
I'm not sure if you are using TMPGenc, CCE or what but TMPGenc has a 2-Pass VBR (variable bitrate) and CCE has some sort of multipass VBR. I use TMPGenc and have found 2-Pass VBR along with high quality or higest quality Motion Search Precision greatly increases the quality of a video. If you use 2-Pass VBR along with a template at some point further on you can select the size of your CD and adjust the bitrate to fit on the one CD. For CVD's and SVCD's I usually try to stay above an average bitrate of 2000 and start testing at a maximum of 3600. Under certain circumstances (usually mostly light colored scenes and not lot of fast motion) I have gotten good results with as low as a 1700 average bitrate. In your case it would be best to split a movie into two AVI's and then adjust the bitrate for each to fit on one CD like I just mentioned.
I also know many people here swear by CQ (constant quality.) Each time i have tried CQ, either I did not get the quality I wanted, or was not able to fit enough (timewise) on a CD at the quality I wanted.
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 21:10 -
Ripping DVDs as MPEGs using TMPGenc --- loss in quality?
By DieselsDen in forum DVD RippingReplies: 5Last Post: 21st Sep 2010, 12:09 -
TMPGEnc advanced settings for best quality results
By tdavid232 in forum Video ConversionReplies: 1Last Post: 15th May 2008, 18:02 -
New to TMPGEnc DVD Author 3 - Two Questions on Video Quality
By heyjjjaded in forum Authoring (DVD)Replies: 0Last Post: 16th Aug 2007, 12:15 -
What are the current encoders comparable to tmpgenc in quality?
By inuyasha in forum Video ConversionReplies: 24Last Post: 26th Jun 2007, 05:43
