I was impressed with bitvice's quality and gamma correction when trying to produce an svcd of home dv footage. it doesnt have any svcd presets but i copied the setting from ffmpegx to see if it would work. it produced 2 files 1 video (mv2) and 1 audio (aif), what do i do now and will this make a REAL svcd(pal)
regards
apt
You can't use BitVice to make a SVCD. Maybe a XSVCD, but not a real SVCD. The reason is that the SVCD standard demands a ceiling bitrate of 2520 (roughly), but BitVice always goes above this magic number, however low you set the ceiling bitrate.
Sorry..."I have not failed. I have only learned what does not work."
-Edison
Which would produce the best quality?
By langham in forum Video ConversionReplies: 4Last Post: 17th Apr 2011, 12:32 -
How to produce like this effect in After Effects?
By 3thman in forum EditingReplies: 6Last Post: 5th May 2010, 19:54 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 16:46 -
Why Do New Computers Produce Less Heat?
By adalect in forum ComputerReplies: 5Last Post: 8th Jul 2009, 16:03 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
