I'm doing SVCDand have noticed that if i convert with higher videobitrate than 2520kb/s and then want to multiplex before i burn it. BBmpeg show me warnings ("The resulting file may not play back correctly.Try reducing the video bitrate or increasing the video and audiostartup delays") and the movie just "hacks" when i test play it after on my softwaredvd ...? I have SVCD settings in BBmpeg could that be it ,i mean they say 2520 is the max bitrate if you should be certain that your dvd player can run it ??
If you go higher than that you are outside the specification for SVCD. So, it's not surprising if your sofware warns you so.
My standalone dvd player supports bitrate up to 4000kb/s so is there any other program than bbmpeg that i can use when multiplexing..?
Multiplexing Multiplex files?
By mrjust in forum Newbie / General discussionsReplies: 5Last Post: 3rd Dec 2012, 23:54 -
How do I multiplex to FLV?
By Videogamer555 in forum Video ConversionReplies: 5Last Post: 30th Aug 2011, 03:26 -
Hi, need a program to batch multiplex.
By mmdmmd in forum AudioReplies: 2Last Post: 18th Oct 2008, 13:50 -
demultiplex and multiplex ..........HELP!
By efiste2 in forum DVD RippingReplies: 1Last Post: 21st Jul 2007, 17:01 -
Multiplex with two audio streams
By heretic754 in forum AudioReplies: 2Last Post: 1st Jun 2007, 23:44
