  1. are there any sites that list what dvds fit on 1 dvd with menu or without etc, or have to be re encoded. THANKS
  2. Not that I know of, and I see no use for one anyways. If you rip it to your HD, you'll see. If it's still too big, then you remove streams you don't want (which I do anyways). Then, if it's STILL don't fit you have to either split or reencode. It's all there is to it.
