hi folks,
after a lot of good (and some bad) dvd-rips with ffmpeg i decided to asked a further question: where is the difference in the bitrate-calculator between mode-1 and mode-2? I guess it's with and without calculating the audio-bitrate. but it's only a feeling, if you know what i mean.
would be nice to know.
thanks anyway and don't call me a stupid only 'cause everybody knows the answer to the question except me.
may the bitrate with you.
700 MB (mode1)
360.000 sectors * 2048 bytes/sector
= 737.280.000 bytes = 703.1 MB
80 min (mode2)
360.000 sectors * 2352 bytes/sector
= 846.720.000 bytes = 807.5 MB
Basically you can get more MB of video onto a CD with mode 2 than with mode 1, hence you can use a higher bitrate. It has nothing to do with the audio bitrate. If you burn your video as a data disc this is mode 1, if you burn as (S)VCD this is mode 2. -
hi craig,
just want to say "thank you". now there are only 1.233.653 secrets left from ffmpeg ...
If I burn the SVCD with Toast with the multitrack CD-ROM XA option... should I be using the mode 2 for SVCD, or mode 1 for data? Not that I have any clue what CD-ROM XA entails... as far as that is concerned I agree with the previous speaker. (Oh to have a clear manual that explains the meaning of all these settings! And how to decide which to use....)
BTW: you only get 2324 bytes/sector in MODE2 Form2 for S/VCD so the total capacity is around 798 MB. This also DOES NOT count for some unavoidable overhead.
Regards.Michael Tam
w: Morsels of Evidence
What is the best Bitrate Calculator ?
By Simmons in forum Video ConversionReplies: 6Last Post: 15th Jan 2011, 08:08 -
bitrate calculator for multiple audio?
By ecc in forum Video ConversionReplies: 4Last Post: 4th Sep 2008, 20:25 -
bitrate calculator
By pcb in forum Newbie / General discussionsReplies: 9Last Post: 1st May 2008, 11:34 -
videohelp bitrate calculator question
By mrgain in forum EditingReplies: 5Last Post: 24th Oct 2007, 15:56 -
Real media Bitrate calculator?
By ViB in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2007, 13:34
