ive downloaded several movies from kazaa(divx .avi) and im getting hissing or static noice while the movie is playing on my pc. its not really a big deal but im wondering if this is normal.
also, when trying to burn the file, as data, just to clear up space on my drive, on nero 5.9 and on cd creator 4, the files are too big, is there a way to get them onto a cd? i use 80min cdr's to burn to.
and after all this is done(after converting to mpeg), will that hissing noise still be on the file? just wondering b-cuz i have other movies that dont have this noise on them
thanx alot
depends on the sie of the file, though you could cut the movie in half with tmpgenc to allow you to fit onto 2cd's
What program can I buy so i can make a vid like gopro hero2 vid
By DROCK71 in forum Newbie / General discussionsReplies: 5Last Post: 21st Mar 2012, 14:01 -
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 11:50 -
downloading a vid from radio-canada.com, but vid isn't available for dwld
By vivimarie in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2010, 12:48 -
Vid encodes will only display first frame instead of loop at the end of vid
By SignedupGuest in forum Newbie / General discussionsReplies: 6Last Post: 8th Aug 2008, 23:09 -
How do i play XVID and DIVX files with my Vid-out (Radeon 9200) on my TV
By azman666 in forum Software PlayingReplies: 2Last Post: 13th Jun 2007, 23:09
