higuys just wanted to tell people how i make my dvd back ups and maybe someone can fne tune what i do and make it even quicker
ok i like my dvds with menus so i do it this way! i used to use ifo edit etc but time is not a problemwith me with 1 pc dedicated to dvd encoding and burning i like to experiment ok here we go 'u need smart ripper , dvd maestro and nero or any other dvd burning programs! and power dvd !
ok rip movie into hd in m2v and ac3 streams format goto stream processing and selct demux to extra file
then with disc in player play disc and when menu comes up on screen capture it with win dvd so u have a bitman pic of menu screen
then load m2v and ac3 streams into dvd maesteo and load menu pic as well from there u can make ure chapter points and menu and burn maestro is very easy if u can master spruce up then ull have no probs! ok so thats how u do it if the files need re encoding m2v then re encde with cce or tmpeg then do the same thing! if anyone can point out any other ways thenthat would be greatbut it only takes about 1 hr or so using 2x media !ok thanks enjoy
The best guide I can recommend for doing such a procedure would be Trilight's:
http://www.trilight.com/guide/
This way you're keeping the animated menu and not just background stills. Plus, the whole thing is already authored. All you need to do is drop your vobs back into the layout.
Good setup to copy NTSC tapes to DVD in Europe?
By Baree in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2012, 14:01 -
How do you copy a DVD onto your IPOD? I have DVD Fab Ripper, any good?
By jacknscoob in forum DVD RippingReplies: 1Last Post: 18th Jan 2012, 05:28 -
How to copy DVD 9 to 5 with menu & extras using DVD2ONE.
By BarryHL in forum User guidesReplies: 145Last Post: 24th Mar 2011, 09:36 -
What is a good price to copy Mini DVDs to DVD-5?
By Des in forum Newbie / General discussionsReplies: 5Last Post: 3rd Dec 2008, 13:54 -
Trying to copy a dvd made using convertxdvd no menu shows up
By brdhsby5 in forum DVD RippingReplies: 18Last Post: 17th Apr 2008, 10:33
