Thread: Need Suggestion: Capture TV/DV to SVCD & burn it on CD.
  1. #1
    I really need help right here. I hope someone might give me some real suggestion to how to doing this.
    Capture Card: ATI TV wonderj
    Software: ATI MMC 7.6
    I got something want to do with my Capture Card.
    I want to record basketball game from TV (SVCD quality 480x480) and burn it to a VCD.
    I want to have the schedule record fuction like the ATI MMC.
    MY problem is the ATI MMC only let me record video for 640x240. What software is best to record SVCD video?? PowerVCRII?? what is your suggestion? I really want to know how ppl do it in vcdhelp forums..... please help.
    WLJ1O1
    I was using this capture card with MMC 7.6 to record a basketball game today.... but.. the quality was so bad and made me very disappointed with MMC 7.6
    so please... can someone tell me which software will do the best job??
    I really want to record some shows to SVCD... with this capture card??
    Thanz!
    WLJ!)!
    Member
    FL, USA
    Posts
    286
    I have the same card, ATI TV Wonder. First thing I would recommend you do is uninstall all of the ATI MMC software and download new drivers from http://btwincap.sourceforge.net Install those and make sure to specify your card and tuner in the dropdowns, I live in the USA so mine is "Phillips NTSC" in the tuner dropdown. Adjust it for wherever you are.
    After that take a look at this:
    http://www.vcdhelp.com/forum/userguides/122161.php
    You can't really capture at SVCD resolution and mpeg2 with what you have. Take a look at the guide in the link and try capping with picvideo at 19 if you have less than 40GB of hard drive space and use huffy if you have more than that. A good resolution is 352x480, that's half d1 and is a valid DVD resolution that you can resize to 352x240 and it will look pretty good. I get good capture-->SVCD with it anyway. Feel free to mail me if you have any questions.
    entirely TOO much time on my hands
    www.easydvdcopy.net
    I just found out how to install MMC 7.7 with my TV wonder in Win98SE.
    http://www.pcphotovideo.com/
    according to this webpage.. it said that SVCD compliant Video (has an SVCD profile) AND ... also makes fully compliant DVD Mpegs as well .. now has 48 kHz AUDIO !! ... yeah i get the 48kHz audio but it still only let me capture ### x 240 !!! do you know why... if I install the drivers from http://btwincap.sourceforge.net.... do i still get the same result??
    I tried to install that driver before... but end up reformat my OS...
    and the MMC Registry Tool by Stinky doesn't work really well with mmc 7.7
    do you think that spend 15US to buy the PowerVCRII on ebay is good?? is there any big different with the demo version if I can crazk the demo to no time limt??
    Thanz
    WLJ1o1
    I can't install the btwincap's drivers.... I have my ATI TV wonder installed....
    it said that i have to install it maually... but i dont' know how....
    also... i can watch the Mpeg-2 video that i capture... i wonder how to watch it.... i install all the codec but.. *sigh*... so tired....
    Thanz
    WLJ1O1
  1. Quick Reply Issue & A Forum Suggestion
    By gonwk in forum Feedback
    Last Post: 15th Feb 2012, 19:54
  2. Replies: 2
    Last Post: 20th Jan 2012, 09:52
  3. Video Capture Device Suggestion - For VCR & PS3
    By dan1st in forum Capturing and VCR
    Last Post: 23rd Aug 2011, 13:33
  4. suggestion & replacement?
    By Thorsenine in forum Editing
    Last Post: 29th Dec 2007, 18:44
  5. Replies: 14
    Last Post: 9th Nov 2007, 07:35
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
