  1. I've been using Bilestyle's guide to in sync SVCDs w/ffmpegX and have had great success but am now having a little trouble with VOBs over 4GB because of the QT limitation. I tried just ripping half of the DVD and then the other half to make each segment under 4GB but QT would still hang on a certain frame. I also tried demuxing and remuxing with various different apps to fix the timecode but I would end up with all the chapters demuxed separately. I then tried joining them together but that didn't work. Is there a way I can demux a VOB and end up with one .m2v file as opposed to a bunch of separate .m2v's?
  2. here's what i've done to make it work. i rip the audio and video off of the dvd. then i take the mpeg into mpegpower tool where you can split it into pieces that are under 2 gb. i then take each mpeg into quicktime to reencode them. after reencoding i use mpeg power tool to put the new mpeg's back together.
    the only part that takes a while is the reencoding in quicktime. you can count on it taking 30-40 minutes depending on the size of the source file.
    after i have the new mpeg i import the audio and video into dvdsp and build a new disk.
    7th layer of hell
    just use my program afropic... it has an option where you can choose the input size of the vob and it takes care of the rest for u.. plus u dont have to convert the ac3 on your own.. its does it all for you....
    any questions just ask
    http://www.anycities.com/user/bilestyle/Files/AfroPic.sit
    As below, so above and beyond, I imagine
    drawn outside the lines of reason.
    Push the envelope. Watch it bend.
    Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind.
  4. Tried afropic and it gives me an error. Probably something I did wrong that is easy to fix.....
    I just looked at the terminal output and noticed I have afropic installed in a folder w/spaces. Could that possibly be my problem? Thanks.
    /Applications/VCD\ Creation\ -\ DVD\ Ripping/AfroPic\ 0.1.2.app/Contents/Resources/shell
    bbDMUX - version 1.9, by Brent Beyeler (beyeler@home.com)
    speed increases by, Apachez and Christian Vogelgsang
    Saving stream 0xBD, substream 0x80 into file audio.ac3...
    File /Volumes/Video/ANTITRST/TITLE01-AN1.VOB is an MPEG-2 Program Stream
    Summary:
    MPEG Packs = 2447147
    Private Stream 1 packets = 180952, total bytes = 365499744
    AC3 Audio stream 0 packets = 180952, total bytes = 364775936
    Padding Stream packets = 14090, total bytes = 14200897
    Video stream 0 packets = 2266195, total bytes = 279673956
    Saving stream 0xE0 into file video.m2v...
    Summary:
    INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
    INFO: [mplex] File video.m2v looks like an MPEG Video stream.
    INFO: [mplex] File audio.ac3 looks like an AC3 Audio stream.
    INFO: [mplex] Found 1 video streams 0 MPEG audio streams and 1 AC3 streams
    INFO: [mplex] Selecting DVD output profile (INCOMEPLETE!!!!)
    INFO: [mplex] Scanning for header info: Video stream e0 (video.m2v)
    INFO: [mplex] VIDEO STREAM: e0
    INFO: [mplex] Frame width : 720
    INFO: [mplex] Frame height : 480
    INFO: [mplex] Aspect ratio : 16:9 display
    INFO: [mplex] Picture rate : 29.970 frames/sec
    INFO: [mplex] Bit rate : 9800000 bits/sec
    INFO: [mplex] Vbv buffer size : 229376 bytes
    INFO: [mplex] CSPF : 0
    INFO: [mplex] Scanning for header info: Audio stream c0 (audio.ac3)
    INFO: [mplex] AC3 AUDIO STREAM:
    INFO: [mplex] Bit rate : 57344 bytes/sec (448 kbit/sec)
    INFO: [mplex] Frequency : 48000 Hz
    INFO: [mplex] SYSTEMS/PROGRAM stream:
    INFO: [mplex] rough-guess multiplexed stream data rate : 9960400
    INFO: [mplex] target data-rate specified : 10080000
    INFO: [mplex] Setting specified specified data rate: 10080000
    INFO: [mplex] Sectors = 89 Video delay = 13019 Audio delay = 13019
    INFO: [mplex] New sequence commences...
    INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
    INFO: [mplex] Audio bd: buf= 16384 frame=000000 sector=00000000
    INFO: [mplex] STREAM e0 completed @ 156176.
    INFO: [mplex] STREAM bd completed @ 203557.
    INFO: [mplex] Multiplex completion at SCR=586234294.
    INFO: [mplex] Video e0: buf= 234628 frame=156176 sector=02266192
    INFO: [mplex] Audio bd: buf= 2048 frame=203557 sector=00180941
    INFO: [mplex] VIDEO_STATISTICS: e0
    INFO: [mplex] Video Stream length: 34959189 bytes
    INFO: [mplex] Sequence headers: 14128
    INFO: [mplex] Sequence ends : 0
    INFO: [mplex] No. Pictures : 156178
    INFO: [mplex] No. Groups : 14128
    INFO: [mplex] No. I Frames : 14128 avg. size107502 bytes
    INFO: [mplex] No. P Frames : 42402 avg. size 26017 bytes
    INFO: [mplex] No. B Frames : 99648 avg. size 19595 bytes
    INFO: [mplex] No. D Frames : 0 avg. size 0 bytes
    INFO: [mplex] Average bit-rate : 343600 bits/sec
    INFO: [mplex] Peak bit-rate : 10195600 bits/sec
    INFO: [mplex] BUFFERING min 15 Buf max 220293
    INFO: [mplex] AUDIO_STATISTICS: bd
    INFO: [mplex] Audio stream length 364775936 bytes.
    INFO: [mplex] Syncwords : 203558
    INFO: [mplex] Frames : 203558 padded
    INFO: [mplex] Frames : 0 unpadded
    INFO: [mplex] BUFFERING min 35 Buf max 8771
    INFO: [mplex]
    INFO: [mplex] MUX STATUS: no under-runs detected.
    ++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
    ++ WARN: [mpeg2enc] If you're not using vcdimager you may wish to turn this off using -d
    /Applications/VCD Creation - DVD Ripping/AfroPic 0.1.2.app/Contents/Resources/shell: mpgtx: command not found
    appending File Browser
    objc: Both /Library/MPipes/AACEncoder.mpipe/Contents/MacOS/AACEncoder and /Library/MPipes/XViDEncoder.mpipe/Contents/MacOS/XViDEncoder have implementations of class MAKFile.
    objc: Using implementation from /Library/MPipes/XViDEncoder.mpipe/Contents/MacOS/XViDEncoder.
    CFBundleLoadExecutableCFBundleGetFunctionPointerFo rNamePluginObject:etDispatch (0x3743A4)CFBundleLoadExecutableCFBundleGetFunctio nPointerForNamePluginObject:etDispatch (0x474C28)CFBundleLoadExecutableCFBundleGetFunctio nPointerForNamePluginObject:etDispatch (0x485118)CFBundleLoadExecutableCFBundleGetFunctio nPointerForNamePluginObject:etDispatch (0x517178)CFBundleLoadExecutableCFBundleGetFunctio nPointerForNamePluginObject:etDispatch (0x534818)CFBundleLoadExecutableCFBundleGetFunctio nPointerForNamePluginObject:etDispatch (0x58CC58)CFBundleLoadExecutableCFBundleGetFunctio nPointerForNamePluginObject:etDispatch (0x609BCC)CFBundleLoadExecutableCFBundleGetFunctio nPointerForNamePluginObject:etDispatch (0x6308FC)CFBundleLoadExecutableCFBundleGetFunctio nPointerForNamePluginObject:etDispatch (0x644F10)CFBundleLoadExecutableCFBundleGetFunctio nPointerForNamePluginObject:etDispatch (0x662610)CFBundleLoadExecutableCFBundleGetFunctio nPointerForNamePluginObject:etDispatch (0x68D170)CFBundleLoadExecutableCFBundleGetFunctio nPointerForNamePluginObject:etDispatch (0x8BBE44)CFBundleLoadExecutableCFBundleGetFunctio nPointerForNamePluginObject:etDispatch (0x8CD864)CFBundleLoadExecutableCFBundleGetFunctio nPointerForNamePluginObject:etDispatch (0x98B89C)CFBundleLoadExecutableCFBundleGetFunctio nPointerForNamePluginObject:etDispatch (0x1258F20)setting Path to audio.ac3
    appending File Streamer
    setting PacketSize to 16384
    appending AC3 Decoder
    appending MP2 Encoder
    setting mp2enc to -V
    starting the pipeline
    Progress: [*.......................................] 0.00%
    ---------------------------------------INSERT 0.01%-99.8% HERE------------------------------------
    Progress: [****************************************] 99.99%
    MP2 Encoder: Please wait as the encoder is finishing the encode
    MP2 Encoder: This might take a few minutes...
    MP2 Encoder: INFO: [mp2enc] Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
    INFO: [mp2enc] format = 0x1, audio length = 2030043099 bytes
    MP2 Encoder: INFO: [mp2enc] slots/frame = 731
    INFO: [mp2enc] frac SpF=0.429, tot bitrate=224 kbps, s freq=44.1 kHz
    INFO: [mp2enc] Fractional number of slots, padding required
    INFO: [mp2enc] System is big endian
    MP2 Encoder: INFO: [mp2enc] Avg slots/frame = Inf; b/smp = Inf; br = Inf kbps
    MP2 Encoder: INFO: [mp2enc] Encoding with psychoacoustic model 2 is finished
    MP2 Encoder: INFO: [mp2enc] The MPEG encoded output file name is "/Volumes/Video/ANTITRST/audio.mp2"
    done!
    **ERROR: [mplex] Unable to open file thefile.m2v for reading.
    rm: thefile.m2v: No such file or directory
  5. no it's not the spaces, they are all accounted for. that's what the \ backstrokes are for, so the Terminal will accept them and the command will be able to execute.
    Since you've already got the streams you can just mplex them seperatly, using somethink like MissingMpegTools @ <www.mac.com/rnc>.[/url]
