Just wondering what people use to capture raw video. I have AIW Pro 128,
1.2GHz Athlon, 1GB RAM, 120GB UDMA 100 IDE HDD. AIW only allows MPEG1 capture and anything above and beyond results in lost frames. I want to capture raw AVI without unnecessary loss of quality.
Firewire IEEE does not work as the resulting video is so jerky, audio not
continous, etc.
Even considering high end capture boards (e.g. the MPEGator series) but not
sure if my computer hardware is the bottleneck.
Computer upgrade is an option but have no clue what I should upgrade to.
Any advice appreciated.
Go ahead and capture to MPEG-1 if your system is already efficient at it. Then just convert your captured file with TMPGEnc (File-->Output to file-->AVI file, etc), or use Virtual Dub (Video-->Compression-->Codec. Save as AVI, etc).
Hello.
Min DV capture, with auto scene file splitting on the fly
By Hitmandj in forum Capturing and VCRReplies: 2Last Post: 15th Jun 2011, 17:40 -
VHS capture hardware (again)
By ccooper in forum Capturing and VCRReplies: 37Last Post: 25th Nov 2009, 13:25 -
By Tom` in forum Capturing and VCRReplies: 12Last Post: 16th Jun 2009, 15:42 -
Need Vista64bit capture hardware/software...
By nhgawe in forum Capturing and VCRReplies: 1Last Post: 19th Apr 2009, 16:26 -
Best hardware capture card for Beyond TV
By videoguy01 in forum Capturing and VCRReplies: 0Last Post: 22nd Feb 2009, 13:39
