  1. Member Conquest10's Avatar
    Chicago, IL
    i'm curious. if you burn a dvd compliant mpeg2 file with dvd file structure on a cdr will it work like a dvd?
  2. i think they are called mini dvds so yes
    PA, USA
    It is called a MiniDVD
    however, not alot of stand-alone DVD players will play them..
    better check the compatibility list on here to see if your's does
