Results 1 to 24 of 24
  1. Sorry don't know where to post , but....
    How do I backup a game from ISO file to CDRW ?
    Got Nero 55914
    select setting CD-ROM :tried ISO (from HD) ---burn --->get ISO(on CDRW)
    select setting CopyCD tried image (from HD) ---> can't select DVDdrive as target
    Need help for newbie
  2. well if it is a iso file then DVD Decrypter should work
  3. It's a game ISO not a DVD image.
  4. well DVD Decrypter burns more than just dvd images. as long as it is a iso file it should burn either on a cd or dvd.
  5. I got a DVD+R drive do you know if it supports DVD+R drives ? Most free software support only DVD-R.
  6. thats a good question i only have tried dvd-r and dvd+rw both work great. well if you could always contact them though emial and ask. just open the program and go to help...
  7. Thanks ghoster!
    you mean you tried dvd-r and dvd-RW not dvd+RW?
  8. no i mean dvd+rw i got that new sony burner that supports all four
  9. No, I can't use it because it will not allow you to choose a source. It automatically assumes the source is a DVD drive. Doesn't have an option to load an ISO file from HD.
  10. thats odd i have some iso files on my hard drive and all i to right click and i have a option where i can select burn using DVD decrypter
  11. Is that the only DVD burning software you have installed?
    I just put a DVDmovie and it won't even copy the main movie VOB files. Probably due to copyprotec.
  12. well the only dvd burning software i use is Nero and DVD Decrypter. i use DVD Decrypter to rip the movie to my hard drive to encode to a smaller size if its over 4.7 gigs. if under 4.7 gigsi use DVD Decrypter and make a iso image form the dvd movie that is in the drive then burn the iso image to a blank dvd. as for nero i create new vob files after i am done encoding and burn them onto a blank dvd using nero
  13. Well...I don't know what to say. It won't alow me to search for a folder as a source (ISO image file) and with a DVD movie it will copy all the VOB files to the HD but not the main movie VOB.
  14. what mode do you have it in IFO FILE or ISO. if its in FILE it should select the main movie if not is should be pretty easy to find
  15. IFO File. It selects it but won't copy it to the HD.
  16. are you using your dvd burner as the drive you are using to rip from? my sony burner won't rip the whole movie either so i had to use my dvd rom that came with my computer in order to get the movie to my hard drive.
  17. No!
    I place the DVDmovie in an HP-DVD+R/+RW drive, then launch DVDdecrypter which recognizes the DVD rewritable drive as the source. Select a folder Video_TS on my HD and tel it to decrypt to the HD.
    no read-only DVDROM involved
  18. that could be your problem because if i stick a dvd movie into my sony dvd burner it won't rip the whole movie it will get a error or stop ripping. so i had to resort back to using my dvd rom drive in order to rip the movie.
  19. Couldn't I just open the DVD with Explorer and just copy the files to the HD ?
  20. you could it takes longer and sometimes it dosen't work
  21. I'm doing it now, it takes about 6-10min.
    Don't see much use for dvd-decrypter
  22. Wow I can't believe nobody answered the poor guys simple question. VideoMann you're not opening the ISO file in Nero properly. Do this:
    1) Start up Nero
    2) When the wizard pops up asking you what type of CD you want to burn select "cancel"
    3) Now at the top menu bar choose "File -> Burn Image"
    4) Find your ISO file and Voila!
    -LeeBear
  23. LEE BEAR'S ABSOLUTELY RIGHT, IT'S AS SIMPLE AS THAT!
  24. OK guys
    I did burn the ISO image using Nero as instructed and the burning went fine. All the folders and dll's appear on the CDRW(finalized).
    However when I launch the CD, I get an error saying
    G:\ "Only part of a ReadProcessMemory or WriteProcessMemory request was completed"
    then I click OK and nothing happens.
    Hmmm???
    Warcraft3 ISO
    Help please
