i just reimaged my computer and was trying to load a mpeg2 file in tmpgenc and couldnt get it to load.it kept saying file unsuported.i've d/l the nemo codec pack and the mpeg2 codec off of the tools page and no luck so far.anyone no where to d/l a mpeg2 codec that will work?
Remember this solution:
-- The Newbie GuidesIf you get an error message when opening the video or audio like file unsupported
or you get an empty(black) video preview window
or the video look wierd in the video preview window like green or purple or pink
Be sure that you have installed the DivX Codecs (both DivX 3.11, 4 and 5) and also try with the Nimo Codec Pack. If that does not work try to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.Hello. -
the mpeg2 codec off the tools page is unsupported in latest versions of tmpgenc .. you need either of the following : ligos player or powerdvd ....
the elecard codec (also being unsupported) causes a lot of problems for tempgenc ...
when you open a mpeg file -- increase the mpeg2 decoder in VFAPI to +2
and DirectShow to +1
or whatever works
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 15:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
