I just got a DV camcorder and have it hooked up to my computer the cam shows up on my computer but how do i take what i recorded on the tape and put it on my computer?
Is the only way i can get what i taped is by playing it on my computer and then using software to record it?
Whats the best software to do this? I tryed some of the programs listed in the help files on this site but i keept getting errors with them i liked Uleads DVD MovieFactory but it didn't have anough settings in it to get what i wanted. Is there anymore programs like that one i thought it was easy to use. -
other that i have used is Showbiz and mydvd. found both on the internet free of charge
well those are the only ones i have used. go to http://www.cnet.com/ and do a search for capture video or something i know they have a lot of software that you could maybe use to get your video onto your harddrive
What is this rambling about capture card?
He says that he got a DV camcorder.
He needs a Firewire-card.
http://www.ubid.com/actn/opn/getpage.asp?AuctionId=8115126
You can transfer the DV data with Moviemaker that comes
with WindowsXP.
Hint: Defrag Hard drive first.
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 22:56 -
Panasonic GS-250 taped race has area of no picture but sound
By helper in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Jul 2010, 05:32 -
How to copy dvd movies to computer and build a liabrary on the computer
By robrpb in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 19:16 -
Computer Guys Braggin' Time: What have you built that AIN'T a computer?
By ahhaa in forum Off topicReplies: 22Last Post: 8th Feb 2010, 16:19 -
Compare VHS to computer vs cheap HD to computer ending in youtube post
By gittarpikk in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 13:06
