I can't find a guide exclusively about VCD2DVD.
I hav e a number of VCDs (2 discs each) I would like to convert to a single DVD.
Can anyone suggest how I link up the 2 cds to encde them to a single DVD
Just copy them to your hard drive ,then:
TMPGE > File > Mpeg Tools > Merge and Cut > Select Type (VCD non standard etc) > Add > Movie 1,Movie 2 > Output > Run."Today is only yesterdays tomorrow" -
Another newbie question: Would the merged file then have to be converted to some kind of DVD format before burning to DVD? I've got TMPGEnc and "My DVD" or some such software that came with the Sony DRU500A.
Thanks -
If I have a divx or mpeg file and I want to convert it to a DVD i have to first convert it to a .m2v file? What program do I use for this?
You need to resample the audio from 44.1khz to 48khz, you dont need to reencode the video as DVD will accept VCD video specs.Originally Posted by airbear
If you have a DVD compliant mpeg2 file you need to demultiplex it, this splits the video stream from the audio stream. This will give you an m2v(video) file and an mp2(audio file). If the file is divx You need to encode it for compliance for DVD specs.Originally Posted by DoGGx23
TMPGEnc can be used for everything you need to do. If you are encoding from divx you can select the encoded output to be in m2v+mp2 rather than mpeg2. This saves you demultiplexing it after encoding.
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 17th Jun 2010, 00:29 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Help with VCD to DVD
By bwheeler in forum Newbie / General discussionsReplies: 9Last Post: 28th Jun 2007, 03:25 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
