  1. I just converted Spiderman Divx DVDRip *not xvid* to SVCD with no audio problems using Virtualdub. When I try to do the same thing with Austin Powers 3 which is encoded with xvid the first half of the mpeg comes out fine but the 2nd the audio is off by 5 or 6 secs. How can I fix this? Thanks
    -John
  2. nevermind I figured it out.
  3. and the solution was ...... ?
  4. I loaded the xvid avi in FourCC Changer and changed the avi from xvid to divx. Then I loaded it up in VirtualDub and split it. Once I had it into 2 avi's I went back and extracted the audio from each avi and encoded with tmpgenc.
