hi
i was hoping someone may be able to help, i need to convert a svcd to vcd but when i load up tmpeg i,m getting a error, (cannot open or unsupported) could someone tell me if theres another program that i can use or am i doing something wrong when using tmpeg.
thanks for any help you can give.
Results 1 to 9 of 9
-- The Newbie GuidesIf you get an error message when opening the video or audio like file unsupported
or you get an empty(black) video preview window
or the video look wierd in the video preview window like green or purple or pink
Be sure that you have installed the DivX Codecs (both DivX 3.11, 4 and 5) and also try with the Nimo Codec Pack. If that does not work try to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.Hello. -
Originally Posted by hunter69uk
SVCD's are MPEG2
You need to have this installed in order to open MPEG2 files in TMPGenc
TMPGEnc MPEG2 Plugin -
well guys, i,ve tried everything you said but nothing seems to work.
thanks for your info anyway. -
i,ve also tried that as well, i think i,ve installed nearly every single codec there is to install but all i get is the same error unsupported or cannot open.
This will work:
Go to Options>Environmental Settings>VFAPI Plug-In>Right-Click on Direct Show Multimedia File Reader and click "Higher Priority" until its at the top."Nothing is difficult, some things just take time"
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 19:37 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 11:27
