I have burned about 7 DVD's successfully now, some encoded some not. Couple quick questions:
1. I keep getting an error "Parsing Error (0xc1070003)" in DVD Maestro when I try to import chapters. I uses Chapter extrator and save as a DVD Maestro file (.chp I believe) I will also select output chapter in DVD Decryptor (.txt file) yet I keep getting this error. I did do it successfully once, but must have somehow screwed things up because I can't do it again. Any advice on how I can get my chapters in DVD Maestro.
2. Do you guys typically burn your movie so that it starts right up in the stand alone player or do you have some kind of title screen or something come up. I think it would be kind of nice to have a title screen and then wait for the user to press play. Can someone please tell me how (or provide url) to add a title screen. Hopefully a solution exists with the programs I already use. Thanks.
Programs I use:
DVD Decrypter
DVD2AVI
Chapter Extractor
TMPGEnc if re-encofing is required
DVD Maestro
Nero
rhuala
---system---
Windows XP Pro
AMD 1700+, 512MB RAM
MSI Geforce 4 Ti4400, Latest detonator drivers
Creative Soundblaster Live
MSI K7T266 Pro2 Motherboard, Latest 4-in-1 drivers
Maxtor 80GB, 7200rpm, ATA66 Hard Drive
Sony DRU500A DVD Burner
Results 1 to 10 of 10
Originally Posted by rhuala2
Try it again.
And also try Ifoedit0.95 as it now supports chapters. -
why don't you just skip that step as well as Chapter Extractor. inless you really want chapters in your dvd. it looks like you encode a dvd if bigger than 4.7 the same way i do. i see no need to use DVD Maestro and Chapter Extractor and all mine i have made has comes out great. just idea if you keep gettting that error.
I do not think your questions/problems was clearly stated.
rhuala -
rhuala -
nope i just rip the movie to my hard drive and run dvd2avi to get d2v and ac3 file. then i load up dv2 file in TMPGEnc to create a m2v file video only. then load the m2v file and ac3 file in ifoedit to make the dvd then burn using nero. plus i was having problems with DVD Maestro so i just got rid of it. really there is no need for it.
hmm, I'm gonna give ifoedit a try, been hearing so much about it but never thought I needed it, thanks.
rhuala -
Usually if chapters fail to import its because your encoding method screwed up the video a little. (I'm not very technical at this, I thik its the iframes that get messed up)
I'm using the SuperNewbie method that I posted in the guides section and have only had it fail once, and thats because CCE will crash on that specific encode for some reason. Using that method the chapters reimport just fine.
Also I use no menus on most movies and make my own super simple menus in Maestro when backing up episodes. -
I think that is the main problem...
give me more info and I help you out....
Zzzzzzzzzzzz
Quick DVD LAB Pro question
By sterankin in forum Authoring (DVD)Replies: 5Last Post: 12th Aug 2010, 05:13 -
TMPGEnc DVD Author 3 - Quick Question on a Setting
By heyjjjaded in forum Authoring (DVD)Replies: 4Last Post: 5th May 2008, 16:04 -
TMPGEnc DVD Author - Quick Slideshow Question
By heyjjjaded in forum Authoring (DVD)Replies: 2Last Post: 4th Mar 2008, 06:13 -
Hi havent done much dvd burning in awhile and had quick question
By pitten247 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2008, 20:10 -
Quick Question
By Scryer_360 in forum Newbie / General discussionsReplies: 3Last Post: 26th Dec 2007, 07:21
