Hello
I have followed the suggestions on the guide on how to fit a long movie in a single CD (800 MByte). Yesterday I recorded "Frequency" broadcasted by TV. I got it through Vdub and HuffyUv at 352x288 PAL stereo (Italy).
I cleaned it out of commercials, created an XVCD following the guide on the site using TMPGenc and then I created a disk using Nero.
The resulting file is precisely 800Mbyte long and was coded at 772 kbps Mpeg1 VBR 2-pass (19 hours....) as the small applet calculator suggested.
I burnt as "non standard" VCD with Nero. No problem.
If I play it through Media Player, all is fine.
However once the disk is on my DVD player (a Samsung DVD1E, the combo) the vision starts well but becomes scattering and blocky, with some "blue screen" in the middle; the disk is actually unusable with this DVD player.
Does anybody know if the problem can be:
a) this DVD player does not support Mpeg1 VBR?
b) 772 is an odd number, maybe the DVD would like 700 or 750 ?
c) I forgot some "clever" trick in encoding or mastering ?
d) I should do something to my Samsung' (firmware, code and so on)
Thank you to anybody who'd be able to help.
Ciao
I think your DVD player probably doesn't support (X)VCD's. It could also be due to cheap, bad media.
:P
Sounds most likely what the problem is..Originally Posted by mtamilia
You could try re-muxing the MPEG as SVCD.. that may do the trick
i dont think that DVD players really care if the bitrate is a even numberb) 772 is an odd number, maybe the DVD would like 700 or 750 ?
See question a. regarding remux as SVCD
What is the best way to author a dvd...AKA GET RID OF THE JITTERS!
By burrowsfan in forum Newbie / General discussionsReplies: 12Last Post: 20th Feb 2009, 13:57 -
EZ (aka lazy) way to dvdrip with multiple audio and subtitle?
By ferjero989 in forum DVD RippingReplies: 1Last Post: 7th Dec 2008, 13:26 -
The baby thread (aka Will Hay question)
By stiltman in forum Off topicReplies: 1Last Post: 22nd Aug 2007, 23:23 -
New ActiveX (aka viruses and trojans)
By stiltman in forum Off topicReplies: 0Last Post: 16th Aug 2007, 11:26 -
VCD to DVD (TDA error: GOP too long)
By jelir in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 10:40
