Hello,
I recently bought my first VCD'd they will not play on my mac's CD-rom or DVD-rom. I have tried quicktime, and all the MACvcd players, with and without speed tools. DVD player is no help.
I also cannot convert the .dat's because the .dat's cannot be copied off the cd. The error message i get whenever i try any thing is "format not recognized" which dosent make any sense. So the encoding on these is "different".
anyone know any special trcks????
thanks
HIYA!
If you boot into OS 9 directly, you can open the .DAT file in Quicktime. This is an option if you want to try it.
What I would try in your situation is using the Application called "Video Lan Client". This one plays nearly everything except of Chess and Stud Poker.
You can get it here: http://www.versiontracker.com/moreinfo.fcgi?id=14738&db=mac
But it will only play on osx. -
you can rename .dat from vcds once you tranfer to h/d
to .mpg plays then,though i have no apple product, i use
windows, not sure which media player u guys use....
DAT to DAT cutter?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2010, 11:13 -
.Dat File?
By niteghost in forum Video ConversionReplies: 3Last Post: 24th May 2009, 21:38 -
I have a .DAT file and don't know what program I need to open it
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2008, 15:42 -
avseq01.dat
By Ozflozz in forum Newbie / General discussionsReplies: 6Last Post: 30th Dec 2007, 21:47 -
Anyway to fix a .dat?
By demonwarrior in forum EditingReplies: 2Last Post: 19th Jun 2007, 04:30
