  1. was wondering if its possible to do anything similar with mp3's when burning them as when burning vcd/svcd using Nero...
    as many of you know, there is a option in Nero to make a menu when burning a vcd/svcd... as for example: you burn a few vcd/svcd files onto a cd, then choose the menu of your choice in Nero and burn it so you can see what type of vcd/svcd files you have burnt to the cd on your tv-screen when playing it on your dvd-player...
    now, is it possible to do the exact same with mp3's as with vcd/svcd files??
    thanks for any replies
    frozenQ
  2. Yes it is possible, but it is not built into Nero. You will have to use a Menu generator or an autorun program to do it. Of course, this will not have any effect when you playback in a stand alone DVD or portable / Car MP3 player. It will just work on your computer.
  3. i see, thanks for the reply
