Hi
I've researched through the converting section, it says tmpgenc can take dv avi, but when I tried to open a movie (rendered in microsoft movie maker v2 beta, dv avi format), tmpgenc said that it needed "video for windows" codec, where can get this?
thank you lots in advance for answering.
Always share what you have learned from others...
Are your Nimo Codecs loaded (see tools at left).
Hello. -
i don't know how to check if nimo codecs are loaded. i just want to open my dv avi file, but it just cannot load, here is the error it gives me. how can i load a dv avi into virtualdub? thank u for any help you give.
Always share what you have learned from others... -
I have a similar question but with a different problem....
When I tried to open several different DivX file in different occasions, TPMPeg gives the "[file location]...can not open or not supported. I have tried to change the header code to Divx3,4 and even XviD, but none seems to help. Has anyone else encountered this problem before?
Any suggestion or help is greatly appreciated.
P.S. the clip opens fine in Premiere
Problem with opening AC3 in VirtualDub
By andy_blah in forum AudioReplies: 5Last Post: 6th Nov 2012, 17:25 -
VirtualDub, problem with *.ts opening
By UMO in forum Newbie / General discussionsReplies: 0Last Post: 27th Feb 2010, 16:50 -
TMPGenc crashes when opening avi
By Kromgol in forum Video ConversionReplies: 4Last Post: 19th Jul 2009, 10:03 -
Trouble opening avi in Tmpgenc 3.0 Express
By davexnet in forum Video ConversionReplies: 1Last Post: 11th Dec 2008, 12:07 -
having trouble opening an avi clip from a Canon ELPH SD600
By Webster in forum Video ConversionReplies: 7Last Post: 12th Aug 2007, 19:06
