Simple question (I hope):
What looks better at the same resolution and bitrate, MPEG-1 or MPEG-2 video?
The obvious answer is MPEG-2, but then why does MPEG-1 still exist as a standard? Compatibility? It seems logical to "upgrade" the VCD specs to include MPEG-2.
Or do the advantages of MPEG-2 only show up at higher resolutions/bitrates, like those used in SVCDs?
Is my newbishness showing?
SVCD is the "upgrade" from VCD. VCD specification development stopped evolving at VCD 3.0. Once DVD was a certainty the Chinese couldn't stop the world from adopting, SVCD specification development stopped at SVCD 1.0.
Mpeg1 and mpeg2 looks pretty much the same if you use
same size and bitrate.
Mpeg2 have flags for interlaced and 3:2 pulldown
that is usefull for higher visual quality. -
As far as encoding, MPEG2 is capable of being 20% more effecient with the same bitrate as MPEG1, but (according to the MPEG Guide), only super-expensive encoders can do this.
Most entry level/free encoders will be roughly equal, or MPEG2 might even be slightly worse (ie older versions of TMPGenc).
Basically, MPEG1 was 'optimized' for a 1.5MBPS data rate, while while MPEG2 was optimized for 3,6 and 8MBPS for the 3 main frame sizes.
So, as you increase the bandwidth for MPEG1, it becomes less effecient the MPEG2.
The big difference is in "meta-data". Both formats carry flags to tell the decoder information, but MPEG2 has many more flags, such as those mentioned above (interlace/3:2 pulldown), and also D-frames, Slice, half-samples, etc.
Basically, MPEG2 can do everything that MPEG1 can do and better.
Why still use it??
Many DVD players will not play MPEG2 on a CD.
TMPGenc is only free with MPEG1.
Many computers will not play MPEG2
MPEG1 is capable of the same Frame-sizes and Bitrates as MPEG2.
If your DVD player can only play compliant VCD and SVCDs, then MPEG2 can make a huge difference, but there isn't much difference between xVCD and xSVCDs....
Nick
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38
