Hello all !
First off, excellent webpage, it has helped me out a lot !
Secondly, I have a video capture question i'd like to ask.
I'm trying to transfer my vhs tapes over to vcd
I'm using a standard memorex vcr, hooked into my video capture card (ati tv wonder pci bus).
The software that i'm using to record it is called Cyberlink Power VCR II.
It works great, it's easy to use, and the quality is good for the size of the files it creates. ( mpeg-1 , 352X240 , 29.97fps , 1150kbps , Layer-2 44100Hz, 224kbps )
The resulting files that i record are perfect, except when i use TMpg to do some editing and chopping.
I noticed now that when i cut a file into several parts, those individual parts are now out of sync, i.e. the sound does not match up with the video. And where i chopped the last file, doesn't actually chop it where i wanted it to chop. i.e. plays 2-3 seconds after i chopped it.
Could this problem be because of the Cyberlink Power VCR II software.
Or is it a Tmpeg problem.
I've tried using VirtualDub, but that capture software won't recognize the vcr somehow !!
Any help would be greatly appreciated !!!!
thanks
Are you saying that vdub does not recognize your video card, or that you are not seeing the video you are pumping into the card from your tape vcr? If you run vdub and go to file/capture avi, you should see a preview window that displays the video you are feeding into your video-in port. If you're not seeing this, you will need the WDM wrapper.
Regarding the sync problems, I believe if you capture to AVI using vdub, you can edit there and not get the sync problems. It's better to capture in vdub, edit, apply filters, and then frameserve to tmpgenc's vcd template.Live every day to the fullest as if it is your last, because someday it will be. -
yeah i find using VDub, the files are way too large, and when i open up VDub, i go to file, then i choose capture avi!
then i get a blue screen with lines, nothing else.
And i'll quickly exit VDub, then open up power vcr II, or windows movie maker, and the tv will appear !
Newbie StaxRip problems
By breck in forum Newbie / General discussionsReplies: 4Last Post: 21st Mar 2011, 15:23 -
What to look for in Video Capture/Software 4 newbie?
By rivrbyte in forum Newbie / General discussionsReplies: 16Last Post: 1st Mar 2010, 14:42 -
Newbie question: cannot view/capture older DV tapes
By sinbarambam in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 9th Jun 2008, 08:48 -
Dumbass Newbie Question: MPEG or AVI?
By grahamh in forum Capturing and VCRReplies: 13Last Post: 16th Aug 2007, 07:20 -
Capture in segments...help for newbie!!
By wormdog88 in forum Capturing and VCRReplies: 0Last Post: 10th May 2007, 08:37
