  1. Hi All,
    After using Soft Encode- I can't get the .ac3 (5.1) to mux properly with the .m2v file. Tried using DVD Junior, and SpruceUp.
    Also, during playback of the .ac3 file- it's fast (chipmunk-y).
    I've encoded @ 48 kHz/ with different bit rates to no avail.
    Can anyone share some 5.1 encoding parameters that has worked for them with Soft Encode (or recommend a different 5.1 encoding program).
    --Joe
  2. Member Nolonemo's Avatar
    Los Angeles
    If you mux using TMPGEnc (use the utility) can you import the resulting .mpg into your authoring program? That's what I do with Softencode AC3 to be able to author with DVD Workshop.
  3. I was unaware (or misinformed) that Tmpge did not support 5.1 .ac3 files. It does?
    What are the paramaters you use for encoding? Anything special I should know about? I don't know why I'm getting the "chipmunk" sound out of my .ac3 files.
    Any advice much appreciated - I'm at a standstill for the past 5 days now!!
    --Joe
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    make sure you do high quality conversions from 44.1 to 48 (if you do, sounds like your main problem or bad offset or somthing) -
    set the following for home dvd ac3 5:1
    384 bit rate
    48khz sample rate
    dialog noramilization -31 to max -25 (normal is -27) -31 is off
    mix level -707
    all high pass filter . all low pass filters
    surround channels 90 degree phase shift (optional - used only on some home decoders)
    RF modulation protect - ON
    Film Standard
    or
    Film Light
  5. Thanks!! -- I'll give it a try tonite. Wish me luck-
    Joe
