hi all.
pardon my newbness, but i just got a dvd+r burner that is compatible with my stand alone player. i have numerous svcds that are two, three, and sometimes 4 discs long. my plan is to do a lot of combining and hopefully put 2-4 svcd and/or vcd on one of the dvdr disc and create a menu system that links to the different movies. any ideas on how i should proceed, like what software i would need, etc. like i said, pardon my newbness, but i just got the dvd burner and dont know anything about it. (it came with my new office pc).
thanks
Tmpeg to demux the SVCD mpg files. You'll need to resample the audio to 48000 using Tmpeg. Rename the audio file .mpa. you should now have an .m2v and an mpa file. Use SpruceUp to author DVD. If the movie spans two or more disks you'll need to join them before demuxing,use DVtool for the mergeing. All software is available in the Tools section on this website.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14 -
Creating menu for DVD Architect project with mutliple events (mpeg2 clips)
By mitchellfox in forum Authoring (DVD)Replies: 3Last Post: 8th May 2007, 16:34
