Whn watching the harts war dvd,when the germans speak german english subs come up so u know what there saying,but when i rip it to my hard drive with smartripper thoughs subs aint there so when watching the svcd i wont know what the germans r saying.
How do i rip out them subs and incorarate them into the svcd.
this is the stream info.....
Stream[001] X=[[0xE0] Video PAL 720x576] [PTS 0:04:47] [Delay 0 ms] [@0] []
Stream[002] 0=[[0x80] Audio English AC3(6Ch) 48kHz Normal Caption] [PTS 0:04:47] [Delay 0 ms] [@57] [448 kb/s]
Stream[003] 0=[[0x81] Audio Czech(Ceske) AC3(6Ch) 48kHz Normal Caption] [PTS 0:04:47] [Delay 0 ms] [@57] [448 kb/s]
Stream[004] 0=[[0x82] Audio English AC3(2Ch) 48kHz Directors Comments] [PTS 0:04:47] [Delay 0 ms] [@57] [224 kb/s]
Stream[005] X=[[0x83] Audio English AC3(2Ch) 48kHz ] [PTS 0:04:47] [Delay 0 ms] [@57] [224 kb/s]
Stream[006] X=[[0x20] Subtitle English Normal Caption] [PTS 17:23:27] [Delay 62320 ms] [@25232] []
Stream[007] 0=[[0x21] Subtitle English ] [PTS 17:23:27] [Delay 62320 ms] [@25235] []
Stream[008] 0=[[0x22] Subtitle Svenska Normal Caption] [PTS 17:23:27] [Delay 62320 ms] [@25235] []
Stream[009] 0=[[0x23] Subtitle Suomi Normal Caption] [PTS 17:23:27] [Delay 62320 ms] [@25235] []
Stream[010] 0=[[0x24] Subtitle Norsk Normal Caption] [PTS 17:23:27] [Delay 62320 ms] [@25235] []
Stream[011] 0=[[0x25] Subtitle Dansk Normal Caption] [PTS 17:23:27] [Delay 62320 ms] [@25235] []
Stream[012] 0=[[0x26] Subtitle Portugues Normal Caption] [PTS 17:23:27] [Delay 62320 ms] [@25235] []
Stream[013] 0=[[0x27] Subtitle Polish Normal Caption] [PTS 17:23:27] [Delay 62320 ms] [@25235] []
Stream[014] 0=[[0x28] Subtitle Czech(Ceske) Normal Caption] [PTS 17:23:27] [Delay 62320 ms] [@25235] []
Stream[015] 0=[[0x29] Subtitle Greek Normal Caption] [PTS 17:23:27] [Delay 62320 ms] [@25235] []
Stream[016] 0=[[0x2A] Subtitle Magyar Normal Caption] [PTS 17:23:27] [Delay 62320 ms] [@25235] []
Stream[017] 0=[[0x2B] Subtitle Hebrew Normal Caption] [PTS 17:23:27] [Delay 62320 ms] [@25235] []
Stream[018] 0=[[0x2C] Subtitle English ] [PTS 5:35:27] [Delay 19840 ms] [@5290] []
Stream[019] 0=[[0x??] Others] [] [] [] []
can you say which part of the movie should have the subtitles, like what happened before and after?
i just took a look at my rip of region 1 of hart's war...the subtitles look to be hardcoded onto the video itself...i'm guessing that PAL must mean you're in another region...region 2??
anywayz, then you need to rip the subtitles manually using extra proggies...once you do, just find the correct subtitle stream (should be towards the end, since the closed captioned subtitle steams usually come before the forced captions subtitle streams...
vobsub/vdub or flaskmpeg -
Yeah its pal r2.Im in the uk.
See near the beginning in the geep,when that german shoots the american in the head,thay start speaking german then and english subs come up at the bottom so u know what there saying.
Maybe on the pal dvd the flags or something that tell the dvd player to turn the subs on and off when the germans speak.
Quick Reply Issue & A Forum Suggestion
By gonwk in forum FeedbackReplies: 2Last Post: 15th Feb 2012, 19:54 -
add Disable automatic tool link to quick reply?
By lordsmurf in forum FeedbackReplies: 0Last Post: 12th Apr 2010, 09:51 -
Can not reply to this thread
By Noahtuck in forum FeedbackReplies: 0Last Post: 6th Aug 2009, 14:20 -
Quick reply error
By stiltman in forum FeedbackReplies: 2Last Post: 26th Nov 2007, 14:06
