Unfortunately my only computer is a laptop, so I end up having to buy the more expensive external harddrives and burners and the like. I just found out about external enclosures, some of which are less than $40 that claim to work with IDE drives and connect with a firewire or USB2.0.
My question is, does anyone have any experience using an external enclosure with a Sony DRU-500A? Is it possible? Also, is there any difference b/w "EIDE" and "IDE"? The external enclosure claims to work with an IDE interface and the Sony seems to require an EIDE interface.
FireWire IEEE 1394 & USB 2.0 External Enclosure for Hard Drive, CD/DVD Drive - $118
http://store.yahoo.com/cdrdvdrmedia/firi13usb20e.html
I purchased one of these for my DRU500A. It works great. Also two of my friends in town also bought the same exclosure.
One GREAT media is the ACCU -R 1x for $.84 in quantity of 100. These work on my Sony.
http://store.yahoo.com/cdrdvdrmedia/higqual47dvm6.html
Also try the Meritline +RW 2.4x for $3.48. Works in the Sony.
http://store.yahoo.com/cdrdvdrmedia/dvmeddvdplus1.html -
i have had no problems with the drive.
device manager will not see it directly but windows programs will. -
Think I might need one of these, can't see anything below $60 though, can you tell me where you found that $40 unit and if you ended up getting it?
Also I wonder if they have any models that connect to the small Sony Firewire port. Might need an external power orf course.
External HDD Enclosure Question
By Timex in forum ComputerReplies: 4Last Post: 1st Aug 2011, 14:53 -
External Harddrive Enclosure
By AuroEdge in forum ComputerReplies: 0Last Post: 3rd Jan 2010, 13:20 -
This External hdd enclosure only confuses the sata vs eSata issue for me
By gll99 in forum ComputerReplies: 13Last Post: 12th Mar 2009, 22:01 -
Have they created an external enclosure for pci cards?
By yoda313 in forum ComputerReplies: 13Last Post: 21st Aug 2008, 23:58 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 12:52
