TMPGEnc 2.59 is now out.
http://www.tmpgenc.net/e_main.html
Results 1 to 9 of 9
Sorry if this is a dumb question, but which processors have Hyper-threading? I have a P4 1.6Ghz, will this help me?
Hyperthreading will not help you. I believe Hyperthreading support starts on the 2.4ghz processors.
Again a dumb question...
I have a P4 2.4Ghz with 1GB RAM.
Will the hyperthreading help me? WHAT IS 'hyperthreading'?
Sorry for sounding stupid! -
Hyperthreading makes the newest Pentium 4 processors look to the OS as dual P4 processors & should be a slight spead increase.
BUT if you have WinXP HOME you are sh*t out of luck as that OS only supports 1 processor - you have to upgrade to WinXP Professional to use "multiple processors".
There are articles online that explain this in excruciating detail. I thinl www.extremetech.com had one.Panasonic DMR-ES45VS, keep those discs a burnin' -
I just check the Intel website, only the newest 3.06G Processor support Hyper threading and also you need to verify the Chip set being using supports Hyper threading, i.e.845E.
the xeon proccessors (2.4 and up - on 860 and 7500 chip sets) also support hyperthreading and with dual xeon's ... it makes the OS think there is 4 cpu's .... sweet ...
Main Concept 1.3.1 , eyeon digital fusion 4.0 , TNPGenc 2.59 all support hyperthreading ...
not many apps do at this point (support hyperthreading) but non the less , most of the time, you still get some added performance (not always) ..
on apps that do support hyperthreading you get 100% on all 4 virtual cpu's like this if you need it :
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 07:57 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
