I got a AIW 8500 and use MMC to capture from VCR
1. Should I checkmark the 3:2 pulldown and deinterlace box when capturing or should I leave it unchecked??
thanks....
and try to reencode to VCD afterward
If you ever want to watch your capture on a computer monitor or projector yes deinterlace. Use pulldown if you are capturing from a source which began life as a 24fps film (ie 95% of DVDs) You must capture at a frame size larger than 352 by 240 or the second field will be 'thrown away' I strongly suggest you use MMC 7.6 (not 7.7) to cap mpeg 2, 720 by 480, I-frame only 15 mbps, deinterlace, full motion estimate quality and pulldown only if using S video in from a non-macrovision DVD player. This will give you about 6 gb per hour mpeg file. You can reencode to vcd with tmpegenc or Xmpeg/flask with lsx or cce plugin (xmpeg/flask is much faster)
Deinterlace?
By ZedsDead in forum Video ConversionReplies: 6Last Post: 15th Mar 2010, 00:21 -
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 13:21 -
To deinterlace or not deinterlace...
By Nilfennasion in forum MacReplies: 4Last Post: 4th Dec 2008, 01:46 -
Do I need to deinterlace? Or never deinterlace?
By rbatty11 in forum Video ConversionReplies: 12Last Post: 17th Jan 2008, 14:15 -
I am an idiot - Blurry Images on Fast Cars.......interlace or capture prob?
By coolstuffiniowa in forum Newbie / General discussionsReplies: 5Last Post: 19th Dec 2007, 21:19
