Hi,
Get this error message with some avi in virtualdub:-
Improper audio encoding in avi. This may introduce a 4ms skew. decompress audio, recompress with a constant bitrate encoder (bitrate 127.7+- 0.0kbps)
Can anyone help!!
Cheers
Gary
You need to save the audio as an uncompressed wav file, see this guide.
http://www.vcdhelp.com/virtualdubaudio.htm -
Oh,
What does 4ms skew mean?
I thought it meant a delay between the video/audio (lip sync) and it was giving you a correction factor?
Cheers
gary -
It does mean that there will be sync problems if you dont save the audio as uncompressed before you encode. Use vdub to play the video and the sync issue should become evident, although 4ms isn't much.
4 ms = 4 miliseconds -
I posted a link to a guide showing you how to correct this.
Eac3to "Clipping Detected...2nd Pass" --> Avi2DVD finds no audio stream
By Murk in forum AudioReplies: 4Last Post: 5th Aug 2010, 17:27 -
Error in Variable bitrate (VBR) audio detected
By Russo in forum AudioReplies: 9Last Post: 12th Feb 2010, 09:01 -
Virtualdub has detected an improper VBR audio encoding
By lingoguysw5 in forum AudioReplies: 17Last Post: 26th Oct 2009, 11:12 -
VBR Audio detected
By timmer545 in forum AudioReplies: 16Last Post: 31st Mar 2008, 11:17 -
VBR Audio Stream detected
By luketheduke in forum Video ConversionReplies: 12Last Post: 8th May 2007, 22:17
