I have 6 .mov files which are tracks to be put on one SVCD. With ffmpegx you can only convert 1 mov file at a time and then you get 2 .img files for each which I believe assumes that one such set of 2 .img files is all you want to drag to toast to be burnt on the CD. How do I go about creating a set of .img files which together will create 1 SVCD with 6 tracks?
Thanks anyone!
E.
- either copy and paste the 6 mov files together with QT Player into a bigger mov file (save with dependancies so as it will not take additional disk space), and encode that one,
- either encode separately each file (turn off authoring in ffmpegX) and then use VCD Builder (available from versiontracker.com) to author the mpg files into one SVCD.
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34 -
How do I burn multiple subtitle tracks to a DVD with ffmpegx
By wildgeese in forum ffmpegX general discussionReplies: 6Last Post: 26th Feb 2009, 12:54 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 03:28 -
ffmpegX and multiple tracks
By jelockwood in forum ffmpegX general discussionReplies: 0Last Post: 30th Jul 2007, 11:55
