I have purchased the scanmagic V100 dvd player which i believe is from the Mustek manufacturer. Does anyone know what other badge/model this piece of kit is known as so i can get started with it. One answer from a colleague is that it looks like a mustek V 300 and that region hacks may work on it..
Any Help.....cheers
Hi,
I have the Mustek ScanMagic V100, too. I have tried all known region hacks for the Mustek series on it, and nothing worked. I found a Webpage where the code is sold by ebay. I think, maybe I will by the code. The hacks for Mustek V300 from a holland guy does not work for the ScanMagic (he told that it would be the same player, but it is not !).
Greetings
Freak2002
The Scanmagic V100 is really the Mustek V56L rebadged. This player can be made region-free using the remote control (see this web-site). Check out the player specs at:
http://www.mustek.de/eng_/html/produkte/dvd56l.htm
The reviews on this player seem to be quite good for playing all DVD, CD and VCD formats. Have yopu encountered any problems, or it all seems OK?
Hope this helps. -
Hi,
the hacks for the Mustek v56l does not work for the Mustek ScanMagic V100 !
I´m waiting for the real code.
Firmware for Mustek DVD Recorder R100A
By Spot.Zwei in forum DVD & Blu-ray RecordersReplies: 3Last Post: 19th Jan 2011, 10:49 -
.spotlight-v100 folders/adding new firmware
By danielmak in forum MacReplies: 7Last Post: 10th Oct 2009, 01:46 -
Code Free for Mustek Yukai MP76A
By eagle1200 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Sep 2008, 12:14 -
Mustek R100A just died!
By mcgeechan6600 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 24th Oct 2007, 10:14 -
Mustek V56L-5E DVD player How To Reboot remove YUV P-Scan setting
By ImNoSmarterN5thGrdr in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Aug 2007, 09:32
