I understand the difference vbr & cbr, but what exactly is CQ. How does that work?
CQ = Constant Quality. It is a form of one pass variable bitrate encoding. It is much faster than 2-pass VBR but a bit slower than CBR. It will produce better quality results than CBR and in some case comes very close to 2-pass VBR. The main problem with this mode is that it is very difficult to predict the final filesize.
Can't say I have ever used it so 'fraid I can't really answer that.Originally Posted by miketree
TMPGenc Authoring 4: problem with incorrect bitrate
By bpchia in forum Authoring (DVD)Replies: 5Last Post: 3rd Aug 2011, 01:53 -
TMPGEnc Authoring Works - bitrate too high
By ecc in forum Authoring (DVD)Replies: 9Last Post: 19th Feb 2009, 13:06 -
TMPGEnc Xpress bitrate calculations are off
By Taeran in forum Video ConversionReplies: 3Last Post: 24th Sep 2008, 17:17 -
TMPGenc won't allow bitrate to go below 1600??
By bebopdeluxe in forum Video ConversionReplies: 3Last Post: 10th Aug 2007, 18:49 -
ISO advice on what bitrate I should use in TMPGEnc....
By RKelly in forum Video ConversionReplies: 4Last Post: 26th Jul 2007, 12:13
