  1. i have a vcd and the quality is really good and i want to find out how it was encoded the birate and resolution etc. Is this possible?
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Extract the MPEG with VCDGear, then open it with ie LSX MPEG player or something.
    /Mats
  3. If it is a true VCD, and not an XVCD then the standards are set. Bitrate is 1150kbps and res is 352x288 25fps pal or 352x240 29.97fps ntsc
  4. bitrateviewer
    Jul 2002
    http://www.medialab.se/mpgprop_e.html
    small little program that gives you all the parameters of an mpeg file
    "The software said Win XP or better, so I Installed Linux"
