I have attempted to use the higher compatibility mode setting in the included Sonic MyDVD software, however, it still will not recognize the DVD+RW in my Toshiba SD3109. Does that setting do the same thing as setting the compatibility bits? Or is there any other way to do so?
Thanks.
Results 1 to 1 of 1
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 15:14 -
32 bit software compatibility with 64 bit machine ?
By joecass in forum ComputerReplies: 6Last Post: 28th Aug 2011, 09:09 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 09:40 -
HDC setting question, 2 pass + manual bit rate
By jsbenson in forum Video ConversionReplies: 2Last Post: 1st Nov 2009, 19:15 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 11:52
