Has anyone been able to play a plain mpg file burned to a data DVD? I have an Apex-1100W that can play an ordinary mpg file if and only if it is on a CDR. I would be really cool to put a larger file on a DVD+R and play that. This would make it easy to just capture a huge mpg file and drop it on DVD+R for later play. As it stands now, you must do all kinds of authoring BS in order to play your file. Why is this the case for DVD+R and not for CDR?
Thanks.
TRIED IT BUT IT DIDNT WORK
backed-uped my mtv mpgs
94 of them
wont play on sampo 620 that plays mpgs f/cd-r's -
That stinks. It does work well on a 650 or 700MB CDR, but not DVD+R. It must have something to do with the fs it creates on the DVD when you burn it. I was hoping there was a way to fool it into thinking the DVD+R was just a huge arss CDR. Wishful thinking i guess.
I don't know much about this, but i tried mpeg on cd-r. you should try mpeg2 on dvd-+r(w).
vcd=mpg
svcd/dvd=mpg2
Somebody give it a try. I never try this before because, ofcourse, i don't have a dvd burner.There is always one who is always greater. Never give up. -
Even with a SVCD or VCD MPG2 file on the disc it still goes to DVD mode looking for the video_ts files. I think it may look to see if the disc is over 800 Megs and then go right into DVD mode instead of (S)VCD.
It is possible with i.e. Cyberhome 302/402 and a few newer Yamakawa for sure.
If you want more infos see www.vcdhelp.com .... -
I just got a Mintek 1600 from Best Buy for $49 last night and to my delight it did this very thing as well as playing DVD-RW, and MP3's on DVD-R, RW. I'm about to post a review of this player on the Player forum, because I'm very impressed. I think you can do this with your Sampo 620 with a firmware upgrade.
Playing Video Files on DVD Player with USB
By Seachd12 in forum Video ConversionReplies: 5Last Post: 20th Dec 2010, 11:04 -
Pixelation in certain frames while playing files in a DVD player
By aarelovich in forum Video ConversionReplies: 8Last Post: 4th Feb 2010, 15:47 -
playing on US DVD player multiple files....
By theRealness0820 in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2008, 14:09 -
playing files on a dvd player
By rigger1972 in forum Newbie / General discussionsReplies: 1Last Post: 16th Aug 2008, 14:23 -
Playing MP4 Files on a DVD Player
By neumannu47 in forum Newbie / General discussionsReplies: 6Last Post: 10th Feb 2008, 15:27
