Hi I jsut finished burning my first dvd-9 to dvd-5. I was not easy but I made it. These are the programs that I used...
DVD Decrypter
ReMPEG2
IfoEdit
Nero
*All are latest versions
After ripping, encoding, then burning it onto a CD, I played it on both my dvd player (computer) and Stand alone and the video quality sucks. Seems like Jagged edges or the images seem like small boxes. What did I do wrong? Are the programs I used good? What causes the bad quality? I think this might of been from my encoding. Maybe someone has encounter this problem and can troubleshoot me through this.
Thank you
i believe that pixelation is caused by the mpeg encoder... i would check your setting there
You win some, and you lose some, and some get rained out... -
Should I lower it or raise it more? Cause I believe I set it to the max. Any other suggestions?
I have the same exact problem. I encoded it with TMPGEnc, and when I play it on my standalone DVD player, I have some irregularities. Small boxes, irriated sounds, and just a few visual flaws here and there (about every 5 seconds or so)
I encoded it using highest quality .mpg file, and it still doesn't seem to change it much. What should I do? Any help is greatly appreciated.-gb -
Switch to encode with TMPGenc and stay with the wizard specs at first , anywhere between 2500 and 7000 bitrate should look fine ...
good luck
Tony
Minor(?) problem with Intensity Pro analog output
By Dandy J in forum Capturing and VCRReplies: 1Last Post: 18th Apr 2011, 21:58 -
minor compression of movie without any qualityloss?
By perik in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 17:30 -
Minor Problems with DVDClone
By jbd441 in forum DVD RippingReplies: 2Last Post: 19th May 2010, 15:25 -
A minor problem using CovertXtoDVD ( double layer dvd+r needed)
By nadizo in forum Newbie / General discussionsReplies: 11Last Post: 18th Mar 2008, 16:13 -
Really Minor Issue
By k_vic in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 13th Oct 2007, 14:47
