Have I been wasting my time figuring out how to capture from VHS (I had HUGE issues with this), encode (takes hours), author (mixed results), and burn (I made quite a few coasters)?
Could I have just bought a Philips DVDR985, poped in a video casette, and 2 hours later have a perfectly recorded DVD?![]()
I have looked at Philips.com and read various reviews about this recorder on the net. Is it really that fast and easy?
Results 1 to 14 of 14
http://www.bestbuy.com/Detail.asp?m=1&cat=32&scat=&e=11101883
But $900 for a press-a-button solution?
Capturing with a PC gives you options of editing video and audio.
Transistions and special effects etc
But if you want to "press a button" and
have money laying around, go ahead. -
Sure, I want to press a button and have a perfect copy pop out! I've been killing myself trying to learn this stuff.
I had no idea it could be easy. Since I am goal oriented, I do want a fast, easy solution.
I've already spent $600 doing this the hard way.
Now it's for $799.00 at CompUSA. Please go check
http://www.compusa.com/products/product_info.asp?product_code=296718 -
I see it is $799. Well that's too bad for me because I already went over my budget and don't have any more $$$.
I guess what I'm really asking is: Would someone please explain to me that doing it by capturing, encoding, authoring, and burning has some advantages over the push-a-button method.
Any advantages at all???? Please??? -
Fill out your profile so we know what you spent with your $600
This is what I would done:
DV camcorder with pass-through feature like Canon ZR40 etc
(Or a really good capture card)
Use Moviemaker2.0 that is free with WindowsXP,
to import DV file, for cutting and special effects. (save as DV file)
Encode to m2v + m2a with tmpgenc 2.59 ($50)
DVD author with ifoedit 0.95 (freeware)
or Sonic MyDVD (free with dvd burner)
Burn VIDEO_TS folder with NERO. (free with dvd burner)
Any advantages?
If you bought a DVD burner for your PC just so you
could transfer a few old VHS tapes, maybe gotten the DVDR985
would been better for you if you do not have the time to learn.
But if you own a DV camcorder and like to video edit,
backup DVDs to DVDR, backup Harddrive..............
You can do some much more when you do not act like a tool
and buy a "press a button solution" -
Thanks, Tony. I guess that answers my question.Originally Posted by tonyp12
But $800 for a few tapes?
A service company like this can do a few tapes.
http://www.vhs-to-dvd.com
If you have 20+ tapes maybe doing it yourself is more economical. -
I went out an bought a panasonic E-30 DVD recorder and works great. Better check compatability issues BEFORE spending a dime. The Philips DVD+R/RW is not as compatable as the DVD-R/RW! I have several Sony dvd players and NONE of them play the +R/+RW disks.
I make great DVD copies from video tapes and then I have a under $200 burnner to make digital copies of the recorded DVD disks. I also have a Terapin VCD recorder and works well within its limitations. Great for making videos to send others, Cheaply since it uses regular CD-R blanks for video. (AudioCD copies require use of music CD blanks).
JD
JD tinkerer pushin' 60,
A real Life Enemy of the State, see Fed case #01-40080, Detroit.
Computers, Electronics, vintage Audio, Photography Film/digital/3D, N-Scale RR, ,
AKA the "Infamouse Joe Walker" ,Join the Navy & see (1/2) the world. -
I am not sure where you got your information. +R and +RW disks are compatible with just about all Sony DVD-video players. +R is at least as compatible as -R. +RW is more compatible than -RW.
http://www.dvdplusrw.org/resources/compatibilitylist_dvdvideo.html -
The problem with the Panasonic E30 is that you cannot play the DVD-RAM disc on most DVD players. So if compatibility is your main goal, you're stuck using DVD-Rs. Unfortunately, you're not utilizing the unit's best feature (Time Slip and Chasing Play) if all you're using is DVD-R.
Of course you can always buy a DVD player that can play DVD-RAM. But that's adding extra $$$ to your buttom line. -
[/b]
. """" I am not sure where you got your information. +R and +RW disks are compatible with just about all Sony DVD-video players. +R is at least as compatible as -R. +RW is more compatible than -RW.
http://www.dvdplusrw.org/resources/compatibilitylist_dvdvideo.html""""
I did NOT get my information from a mfg supported biased list!
I got my compatability info right HERE!
Sure most of the compatable models may be listed but what models are NOT LISTED on their site?
Anyone can pick a select group of models to skew the results. I looked up ALL my DVD players, several Sony, one Pioneer and my panasonic portable BEFORE deciding on either format. In fact teh DIS-information delayed my selections a little untill I could research the issue more!
:P 8)
Stay with your E30 I have the E20 and my backups of DVD's look as good and most, Better than what a burner can do and in 1/3 the time, I am getting a Burner also but not for this long drawn out Ripping, I want it for home grown DVD Video's and data transfer, the Stand alone DVD recorder is the best thing to come around since the VCR!
what would the best setting for me for Handbrake ? plz answer
By FaisalKhan in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2011, 08:38 -
Philipps DVDR985 error
By nic2k4 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 11th Jun 2010, 01:30 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 16:06 -
Question closed. Reason: answer found elsewhere
By Hurdman in forum SubtitleReplies: 0Last Post: 9th Dec 2008, 02:54 -
Need someone who has seen Transformers The Movie(animated) to answer Q?
By Denvers Dawgs in forum Off topicReplies: 10Last Post: 27th Jun 2007, 20:42
