How can i copy a dvd of double density to a 4gb dvd, without lose the several audio track and subt (i mean reencoding with a low bitrate or something), just kipping the as the original, no big deal with the quality.
Well, there are some guides on this. That would be a good starting point... Basically comes down to only keeping the main title, and the streams you want. Then re-author and burn away... If it still doesn't fit then you have to either split or re-encode it...
Need to add pdf's to authored 9GB DVD then re-compress for 4.4GB disc
By stretchweider in forum MacReplies: 7Last Post: 4th May 2016, 13:40 -
9gb .ts > 4gb .mkv
By NotSoEasy in forum Video ConversionReplies: 28Last Post: 5th Mar 2012, 21:21 -
FAQ didn't answer my question. What's the best DVD-R 9GB media to buy?
By insomnia976 in forum MediaReplies: 7Last Post: 18th Jul 2009, 14:10 -
4.9GB Vid + 2.1GB Aud = 8.6GB?!?!?
By BurkettC in forum Authoring (Blu-ray)Replies: 6Last Post: 10th Jul 2009, 19:43 -
Removing Trailers from a 4.9GB DVD to fit in a 4.7 GB DVD+R
By rotchild in forum Newbie / General discussionsReplies: 5Last Post: 16th Jan 2009, 19:20
