Hey just curious to see what the maximum playing time anyone has been able to fit on a 80 Min CDR, that has been watchable?
Results 1 to 14 of 14
I have done a 2 hour movie on (X)VCD before and playback was good. Some people on this board have gotten up to 2 hours and 30 minutes on 1 CD-R.
:P
1h 50min personally, know some guys that fit 3h 19 min (Apocalypse Now - uncut).
0 kewl, 3 hours and 19 minutes on one CD-R?!?!?!
How did the ouptup turn out, it probably was blocky.
You would be surprised-
The KWAG LBR Template can do 180 minutes of "good" quality when combined with the Blockbuster filter.... especially for low-action movies and widescreen video.
The secret is variable noise reduction/smoothing, plus low I-frame count with the CQ_VBR HQ encoding.
nick -
You got that 99% right nickOriginally Posted by hp_lovecraft
Forgot to add the NoMoSmooth filter
Here's a sample script for anyone interested:
LoadPlugin("C:\encoding\MPEG2DEC.dll")
LoadPlugin("C:\encoding\nomosmooth.dll")
LoadPlugin("C:\encoding\blockbuster.dll")
mpeg2source("K:\TEST\VIDEO_TS\movie.d2v")
BilinearResize(336,192,45,0,630,480)
NoMoSmooth()
######## Auto Strength, proportional strength depending on resolution #####
## Remove only one "#" on front of the resolution that matches your encoding.
BB_Resolution = 352*240
#BB_Resolution = 352*480
#BB_Resolution = 528*480
#BB_Resolution = 544*480
#BB_Resolution = 704*480
BB_StrengthConstant = 352 * 240 * 20 # Base strength
StrengthValue = round (BB_StrengthConstant / BB_Resolution)
Blockbuster( method="noise", detail_min=1, detail_max=10, lv=1 ) # Apply noise if complexity is <= 10%.
Blockbuster( method="sharpen", detail_min=20, detail_max=90, strength=StrengthValue) # Sharpen only if complexity is >= 20%.
# The last ~10% is left untouched (pass-through), to avoid sharpening highest frequency components ( Peak artifacts, sharpest edge, etc. )
################## End Auto Strength ####################
AddBorders(8,24,8,24)
Information, samples and more advanced techniques here: http://www.kvcd.net/forum/viewtopic.php?t=1604
-kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
This is some seriously kewl readings here
My question is, where can I get a hold of the nomosmooth and blockbuster filters for avisynth?
I tried using the sansgrip link provided in the KVCD forums but all the site is either down/moved or really busy.
is there any other places I could get my grubby hands on them
thanks , ciao
TLTwThe Hellsing family will purify this world... -
Hi TheLostTimberwolf,
Apparently, there are network routing problems. Try to access SansGrip's page from this proxy: http://www.webwarper.net
Cheers Kwag
I can now access the site, but downloading seems another matter lol, Ill just keep trying, if there are troubles Im sure time will sort them out
ciao
Well Ive been trying and no luck the links keep coming up dead for downloading the filters
Kwag would it be possible for you to please maybe email me the filters(nomosmooth and blockbuster) or anyone please?
TheLostTimberwolf@hotmail.com
please
thank you
The filters are mirrored hereOriginally Posted by TheLostTimberwolf
: http://www.kvcd.net/sansgrip/avisynth
I am interesting to try out KVCD.
Other than downloading the template for TMPGenc,
is there anythings else we have to do ? -
CD-R'S cost .50¢ you want to give up "decent quality" for that??
"The software said Win XP or better, so I Installed Linux" -
many thanks Kwag
all downloaded, now to work this stuff out lol
catch ya
movie length into a avchd dvd9
By supersam in forum Authoring (Blu-ray)Replies: 11Last Post: 14th Oct 2009, 01:42 -
TMPGEnc Issues with length of movie?
By doctorgonzo in forum Video ConversionReplies: 1Last Post: 11th Apr 2009, 11:30 -
Maximum length of XLR cables
By Graham Archard in forum AudioReplies: 2Last Post: 3rd Apr 2008, 22:03 -
Maximum Length on a single layer DVDr
By acid_burn in forum Newbie / General discussionsReplies: 6Last Post: 16th Dec 2007, 06:05 -
Does WinDV transfer a maximum segment length of 19 minutes, 6 seconds?
By VMiller in forum Capturing and VCRReplies: 5Last Post: 13th Jul 2007, 22:55
