Ok, my question isn't really video related, mostly media. I'm looking for a high capacity DVD for backing up data as opposed to tape backups. The only thing I was able to find was what was listed in this sites DVD FAQ's about DVD-18, ability to hold 15 DS/DL. I have also found another site which details a "Blu-Ray High-Density DVD" that can hold up to 27 gigabytes SS/SL.
Does anyone know which of these technologies is available and where?
DVD-R/RW and DVD+R/RW are only single-layer media. Each layer holds 4.3GB of data (advertised as 4.7GB but that's 1000-byte kilobytes not 1024-bytes). There are dual-sided DVD-writable media, but not dual-layer. There will probably never be dual-layer recordable DVD (reason for this addressed in several posts). The BlueRay technology won't be available for a few years.
So, if I understand you correctly, there are double layer DVD's that are available for reading but not for writing.
Dual layer DVDs have to be pressed (i.e. commercial discs). Theoretically the DVD spec allows up to 4 layers on the same side, but that hasn't been implemented in commercial players.
x264 AVC High@L5.1 to High@L4.1 conversion
By Pr0metheus in forum Video ConversionReplies: 16Last Post: 11th Oct 2013, 14:37 -
[Q] Convert MKV Format Profile from High@L5.0 to High@L3.1?
By xIntenso in forum Video ConversionReplies: 5Last Post: 26th Aug 2013, 21:46 -
Software to Read Variable Density Optical Soundtrack
By jersy in forum AudioReplies: 8Last Post: 7th Sep 2011, 23:03 -
How Increase Density of Frames Displayed? Vegas 9
By solarblast in forum EditingReplies: 2Last Post: 14th Sep 2010, 11:37 -
Increase the density of keyframes
By Stasik0 in forum EditingReplies: 11Last Post: 6th Jul 2010, 07:15
