hey!
can i start two Encodings sessions at the same time with TMPGEnc.?
would it affect the quality and or something elsE?
Thx
Bye!
yes you "can". It'll just take a lot longer to encode the video (and it could possibly cause a crash). I have done this in the past and it worked fine.
Best to set up a batch encode, that way when one encode is done the next one starts. I have set a dozen movies on batch encode before now, the advantage of doing it this way is that if you do have a system crash movies that have already encoded will be fine and you can just restart the batch encode from where you left off. If you set lots of windows encoding at the same time, if you have a crash you will have a bit of all of them encoded, which is no use at all.
TmpgEnc 4 XPress Question
By VEBouto in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2009, 20:36 -
TMPGENC question
By triumph2004 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Aug 2008, 00:21 -
TMPGEnc question.
By Hal05154 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2007, 09:20 -
TMPGEnc Question
By dafoe in forum EditingReplies: 5Last Post: 12th Oct 2007, 05:38 -
FitCD / TMPGEnc question
By Seroster in forum Video ConversionReplies: 4Last Post: 3rd Sep 2007, 13:34
