  1. I am trying to convert an avi. to VCD but whenever I play it on any dvd player the screen keeps turning pink
    Any idea`s on what I`m doing wrong
    P.S. I`m using TMPGEnc to convert it
    Apr 2002
    The State of Frustration
    If you get an error message when opening the video or audio like file unsupported
    or you get an empty(black) video preview window
    or the video look wierd in the video preview window like green or purple or pink
    Be sure that you have installed the DivX Codecs (both DivX 3.11, 4 and 5) and also try with the Nimo Codec Pack. If that does not work try to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.
    -- The Newbie Guides
    Hello.
  3. I set the Directshow to 1 & its working fine now
    Cheers
