Thread: PAL to NTSC question (Not an issue of how to convert)
  1. #1
    I have some tv episodes that i would like to make VCDs out of so i can watch them on my tv through my dvd player and my NTSC tv. Some of the shows are downloaded and they are PAL. I Tried converting the PAL shows to NTSC but I get kinda-jerky playback and audio problems. I've tried other methods, but it is beginning to get bothersome.
    My question is, is there a way I can play, on my computer, a PAL file, while at the same time recording it to a NTSC VCD file, then transfer the good NTSC VCD file to cd.
    I'm thinking that this would avoid all that PAL to NTSC troubles and since it would be real-time recording, it can be completed in the time it takes the episode to run.
    any ideas???
    Member
    Milan, Italy
    Posts
    14
    Hi
    I am not familiar with your problem but I am with the opposite. Many recent european DVD player will play NTSC and PAL VCDs, I suppose an american one can also do the same if it is recent.
    Did you try creating a PAL VCD and see what happens in your DVD/TV ?
    I have the opposite problem but the method is the same and
    it works great. You need to extract audio, change the .avi file
    to 25 fps (if it's NTSC to PAL) or to 23.976 fps (if it's PAL to NTSC).
    Now you take your extracted audio and either shrink/stretch with something like CoolEdit it since
    the new converted .avi file will have a different total recorded time.
    Then use TMPGE to make a VCD.
    If you need further explanations let me know.
    Besweet has presets for converting audio from ntsc to pal and vice versa...saves alot of trying out with Cooledit
    Extract the audio through virtualdub...and use aviframerate (or avifrate as it is called on my HD )
    and follow the normal procedure to convert to VCD or SVCD or to what ever MPEG format u want with TMPGenc..
    Just another way of doing an easy job....
    And yes...we all wear wooden shoes here in Holland...
    Hmmm...forgot a sentence....sorry
    Use aviframerate to set the desired framerate (eg.25 or 29,something)....it saves time and space....virtualdub does the same trick...only u have to save it to another avi...avifrate just makes changes to your divx file....
    A sentence???? I could write a whole book....
    Thanks for the info. I guess I will give the whole PAL to NTSC conversion a try again using the methods suggested and see if it solves the problem.
  1. Replies: 33
    Last Post: 28th Nov 2013, 11:33
  2. PAL/NTSC issue
    By redbaron88 in forum Newbie / General discussions
    Last Post: 9th Mar 2011, 09:25
  3. capturing on sony hdr-hc7 NTSC Tape / PAL Camera issue ?
    By DKmickey in forum Camcorders (DV/HDV/AVCHD/HD)
    Last Post: 5th Feb 2009, 14:38
  4. Replies: 4
    Last Post: 7th Jul 2008, 21:45
  5. PAL + NTSC Compatibility Issue !?
    By ells6363 in forum Newbie / General discussions
    Last Post: 19th Jun 2007, 12:37
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
