Is there a way that I can create tracks on a VCD using one large 60 minute mpeg?
I know I can split up the mpeg to multiple file using splitters, but it takes too long (splitting up 1 hour mpeg could take up to an hour!)
I use the dazzle usb capture device and Nero burner 5.0.
Please some one help
kevin
The only way to make multiple tracks is the split the mpeg. Sorry if that's not what you want to hear, but that's the only way it can be done.
Well you can create chapters using either vcdimager (get a gui for easier use,)or I-Author. These will work for both vcds and svcds. If you are just making vcds then you can also use Video pack 4.0.
These programs allow you to insert entrypoints into a single mpeg track which allows you seamless navigation between "chapters" and doesnt require any cutting of the mpeg.
You can still use nero to burn but you might have to do some converting of disk images if you use I-Author or vid pack.
Your best bet is probably vcdimager since its free, check the tools section.
Ive never heard of real time mpeg splitting lol! It should not be taking you that long at all. Have you tried bbmpeg? Its pretty fast for splitting.
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
Audio tracks
By siluet in forum Newbie / General discussionsReplies: 2Last Post: 17th Sep 2009, 21:07 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 11:36 -
Audio tracks
By Kelli Lancaster in forum EditingReplies: 0Last Post: 10th Oct 2007, 09:46 -
how to create VCD protection?
By C-W in forum Authoring (VCD/SVCD)Replies: 4Last Post: 18th May 2007, 12:00
