I'm experiencing some problems when splitting mpgs in TMPGenc. After selecting the range of the clip e.g 45 min, the clip ends up much shorter and the output is always somewhere around 24 min, no matter what range(above 24 min) selected. The problem seems to be connected to the program settings but I can't figure it out. I'm quite confident that the problem is quite easily solved, but I'm also confident that I will break my computer into bits and pieces if keep on trying...I would be very grateful if someone could suggest a solution to the problem...
If you are using source range, remember there are two options: To edit out the selected part, or edit out the part you did not select.
Hello. -
Yeah, but I don't think that's the problem since the output always has the same length, and since I'm cutting the file into two parts that are of almost identical length...
Mencoder Splitting problems - Heeeelp!!!!!!
By mh2011 in forum EditingReplies: 7Last Post: 3rd Nov 2011, 14:29 -
Problems with splitting AVI in ffmpeg
By avalk in forum ProgrammingReplies: 0Last Post: 14th Feb 2011, 06:13 -
Problems splitting MP4 with Yamb
By trokua in forum Video ConversionReplies: 0Last Post: 3rd Aug 2010, 23:10 -
problem splitting mpeg with tmpgenc
By jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 09:18 -
VirtualDubMod Splitting problems
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 1Last Post: 19th May 2007, 18:20
