Everyone seems to be talking about quality loss when making the video smaller using tmpeng.
I have been making 7Gb movies into 3.1Gb .m2v files using TMPEng and then burning and think the quality is still great. I just did jackie brown (153min). The bitrate was arounf 3200 I belive.
I have a 32inch sony wega. As long as you sit more then 4 ft. away you really cant tell the difference (you can slightly when the movie has dark scences).
and the funny thing is that I use CBR. I tried VBR and quality did not change.
James
If you think that's good, I've been putting 2 movies per DVD at 352x480. The quality looks as good as it does from my digital cable.
Movie quality is bad after burn to DVD
By ngochan in forum Video ConversionReplies: 4Last Post: 25th Jan 2011, 23:34 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
how can i reender a video with HD quality and around 1gb 4 each hour???
By khalid81 in forum EditingReplies: 9Last Post: 24th Oct 2009, 13:55 -
Microsoft Vista Movie Maker gives best DVD quality
By quickfamily in forum Newbie / General discussionsReplies: 6Last Post: 26th Jan 2009, 15:06 -
5 hour movie on WMP, 90 min movie on MOVAVI
By jchockey in forum DVD RippingReplies: 0Last Post: 24th Aug 2007, 13:14
