I capture one hour and half of DV in Premiere 6.5 and I get the file 27 GB big. If I play this file in Windows Media Player or PowerDVD, everything is OK but when I import this file in Premiere's timeline, the picture progressively goes after the sound. In first 15-20 minutes audio and video are in synch but after that the gap between video and audio is bigger and bigger.
How can I fix this problem?
Thanks...
Hi All,
I am getting the exact problem in Premiere 6.0
Any ideas?
Jose -
I know this is old, but for those who, like me, reach this thread searching for a solution, I'd suggest trying this:
http://www.adobe.com/support/techdocs/27806.htm
Their fix worked perfect for me. Be sure adjust not only the clip audio properties, but the export as well.
strange sounds in audio exported from premiere pro cs3
By codemaster in forum EditingReplies: 0Last Post: 25th Jan 2011, 19:57 -
Premiere Audio Sync Problem
By Cedrick Salizar in forum EditingReplies: 1Last Post: 11th Jan 2010, 12:01 -
Strange audio sync problem with downloaded AVI
By embreeb in forum AudioReplies: 9Last Post: 9th Dec 2008, 09:30 -
Strange Audio Sync Problem
By innovyse in forum Video ConversionReplies: 2Last Post: 6th Dec 2007, 14:36 -
strange buzz in audio/subs out of sync
By mique in forum ffmpegX general discussionReplies: 1Last Post: 11th Oct 2007, 19:46
