Hi! I tried to rip DVD using Smart Ripper,DVD2AVI and TMPGEnc(sefys guide).First I have to say this DVD has 2 45 minutes shows which goes one after another with about 1 minute break.I encoded first part of file without a problem (which happens to be first show from beginning to the end).I used end frame from 1st part as start frame for 2nd but I have no idea what is the end frame for part 2.Its showing 0 or the same number as start frame.And where I can select true movie ending frame as guide says?Thanks .
